NRALIFR
Feb 05, 2016Explorer
As the old saying goes: "Time flies when you're having fun".
Here it is almost ten months since my last update and there have definitely been some fun times. Working on the garage, taking trips in the camper, enjoying spending time with family (especially the grand-daughter). There's also been some not-so-fun stuff, and that has been partly responsible for the delay in updating this.
The fun stuff:
We finished sheet-rocking the ceilings in the garage. The lower bay required renting a scissor-lift. Scaffolding would have been too much trouble to move around.
Closing up the ceiling in the lower bay made the garage easier to heat when it's cold, but it also made it harder to ventilate when it's hot. So, I installed an attic fan in the lower bay that I had removed from the attic over the main house several years ago.
The temporary wiring has since been replaced with the proper stuff.
I installed it on top of the ceiling joists rather than cutting one. I initially planned to buy a new style shutter that's designed for this type of installation, but after running it without a shutter I realized that most of the noise I used to attribute to the fan when it was in the house was actually the shutter rattling. The fan with no shutter is actually pretty quiet! I'll probably just finish this hole off with trim and use some 1/4" hardware cloth as a screen. Since I have easy access to the attic, I can always just throw a blanket over it in the winter to keep the heat from escaping.
The next project was to install the mini-split HVAC unit for the new living area above the garage, and the gas fired heater in the garage lower bay.
Because I still have landscaping to do around the garage foundation, I built a shelf on the back wall to set the outdoor unit on. The shelf is supported by four metal brackets fastened to the wall studs. I ordered the brackets from Rockler Woodworking.
The HVAC installers set the outdoor unit.
And the indoor unit.
And then ran all the associated plumbing and wires.
Works good, lasts a long time..............................................NOT!!!!
To my infinite (and beyond) sorrow, the boss was not happy where the indoor unit was on the wall. I thought we had this all worked out, but I apparently misunderstood and had them put it in the wrong place. Totally my fault, but nothing a few more $$$'s wont fix. Actually, I've found with this project that there is virtually no problem you can't make disappear if you just throw enough money at it.
So, the guys come back out, work some magic for a few hours, and the inside unit is now where it should have been installed the first time (dummy!!!). The hole in the siding is behind the cover over the outside plumbing, so it will never be seen, and I'll be able to easily patch the siding from the inside by removing a piece of sheetrock. No problem!
The dear boss and the dear deer (see the one laying down?) are both happy now, and my life is again worth living.
We've now used the mini-split for both cooling and heating, and I can say without any reservations that it works great. It heats and cools very well, it's very quiet both inside and outside. You can hardly hear it when it's running. It seems to be pretty efficient, too. Our combined gas/electric usage is virtually unchanged from last winter, despite the fact that I've burnt almost no wood for heat this winter. The weather this winter has not been conducive for using the wood-stove for heat. The nights are cold enough, but the the daytime temps have mostly been too warm. Having to start a new fire in the stove every night is a pain.
A gas-fired heater was hung in the lower bay close to the ceiling. The flue runs horizontally out the side wall. This thing works good, too. It brings the garage up to a comfortable temp quickly. I've found that I need to install a fan to help circulate the air between the bays though, because the heat tends to accumulate in the upper bay.
The attic fan and heater controls. I like the timer switch. Don't have to worry about forgetting to turn it off.
Now, the not-so-fun stuff:
Like a lot of people, I've found that as I get older some of the well used (and abused) joints start wearing out. Knee and shoulder injuries are pretty common for active guys my age, with shoulders probably being the most common to have problems. I destroyed the ACL in my right knee about six years ago, and had that fixed. Fortunately, it doesn't give me much trouble today. But, I've apparently been working without rotator-cuff muscles in my right shoulder for several years, because the injuries were already too old to fix when I first started seeing a Doc about three years ago because of the pain. The only fix available for that shoulder is a reverse shoulder replacement :( , but hopefully that's a few years down the road yet. The left shoulder is injured as well from a fall on the ice a few years ago, but it's not in as bad a shape as the right.
Anyway, sometime last summer I managed to tear the deltoid muscle in the right shoulder. I'm not sure what I was doing that started it, and I didn't even realize what was happening because it was a small tear with no external signs. The shoulder continued to have full mobility, but I continued to tear it little by little over 3-4 months, until just before Christmas I lost shoulder mobility and developed an ugly bruise on my arm. The bruise started out small and looking like I had torn the bicep, so I was scheduled for arthroscopic surgery to fix that. By the time surgery day rolled around, I had a technicolor bruise from my shoulder to the elbow.
When the Doc saw that, he said "That's not just the bicep". He started out with the scope, but eventually had to make a 3" incision to stitch up the deltoid. In addition, the long head of the bicep was cut loose (tenotomy) to relieve some of the pain it was causing. The Doc was also able to confirm while he was in there that the rotator cuff is irreparable.
I'm doing physical therapy now, and can actually do quite a bit with that arm, except move the upper arm away from my side much. I've got several more weeks of re-hab to go before I'll be able to return to work.
So, I'm at home a lot lately. Rather than going on a Netflix binge, or reading all those books I've been meaning to get to, I've been overseeing a steady stream of workmen taking care of all the stuff that either the boss or I would have had to stay home for.
The first thing I had done, was to finish out the wall in the garage that the upper bay shares with the house. The wall originally had a layer of white Styrofoam bead board, a layer of black fiberboard sheathing, and a layer of fir siding on it. The entry door frame was of course built to match that thickness. To make the surface come in at the same place, a layer of blue foam board, a layer of OSB, then a layer of sheetrock was hung on this portion of the wall. The rest of the garage will just have sheetrock on the walls.
We're now working on the wall in the new living area directly above the one in the garage. To add some strength and rigidity to the wall, and to help smooth out some of the irregularities that were uncovered in the construction process, I had a layer of OSB installed on the "new room" side of this wall as well. The OSB also makes it easier to install the tongue and groove boards that will cover part of this wall (no blocking needed). The original header at the top of the wall wasn't built to support the span in the entryway we are going to end up with, so another header was set under it. The new header also brought the top of the opening down to the same height of the door openings on each side.
The T&G boards going on.
The half-wall and a temporary support post can be seen through the plastic. The post will eventually be replaced with one made from a tree that I'll harvest from my yard. The top surface of the half-wall could be a thick slab cut from the same tree.
That's the current state of things.
The fun stuff:
