NRALIFR's avatar
NRALIFR
Finally Getting Started: New Garage With RV Bay
I've been talking and thinking about doing this for 3-4 years now. Two days ago we finally took the first "ground breaking" step toward making it a reality.
The garage on my house started out as a flat-roof, open-sided carport when the the house was built 40 years ago. Some previous owner put sides on it, but no garage doors. When I bought the place 15 years ago, the flat roof was leaking badly, and the front wall where the two openings are was rotted badly enough that I had to rebuild it before having garage doors installed.
While the house foundation is sound, the garage foundation has had numerous problems from cracking and movement. I've always planned to one day tear it down to the ground and start over. My original plan was to just rebuild a two-bay garage of the same size, but with a peaked roof. Eventually, I realized that by making use of the slope, a tall RV bay could be added without ending up with a roof-line taller than the rest of the house.
Discussing the project with the DW resulted in further "scope creep", such that we'll also be adding a fair amount of square footage to the living area of the house as well. My garage/RV bay/man-cave has ballooned considerably since I first started dreaming, but this is what we've settled on. The old garage is about 28' deep, and 24' wide. The new garage will be 30' deep and 60' wide. The RV bay will have one wide door, rather than the two narrow doors shown. I was planning to allow 14' of vertical clearance, but I'm not sure I really need to go that high. Twelve feet would be plenty for my camper, the garage depth and driveway approach will never accommodate an RV much longer than mine.
About 10 years ago I had an asphalt driveway paved down behind the house, and then had a Jamar RV shed constructed over it where I'm currently parking my truck and camper. It's sitting right where my new garage RV bay will be, so it'll have to be moved. That's what we've started, which doesn't sound too difficult. Except.........
My property is on the side of a hill. There's no naturally level ground anywhere, so a pad will have to be constructed. Also, about a year ago (anticipating the loss of my garage and the storage space inside it) I constructed a 12'x20' storage building right next to the house to hold all of my man-stuff while the garage is being built. Once the garage is built, the storage building will be taken apart and moved farther away from the house. So that's two level pads to construct.
I also have a ton of trees on my property, mostly white oak, some of them pretty big, and pretty close to the house. Of course, there are trees in the way of everything I want to do.
So, Wednesday morning, bright and early, the tree cutting pro's got started. The weather was gray and gloomy that day. This is where my metal RV shed will be moved. I'm going to reduce it's height a little and use it to park other equipment under.
Getting the boom truck setup for another tree.
They were having fun maneuvering that 2WD boom truck around on my slope.
This tree was hanging over my RV shed.
My storage building. They dropped a big limb on it's roof, but it doesn't appear to have suffered any damage.
My truck and camper out of harms way in the front yard.
Wish I had one of those trucks to play with.
Pulling one down close to the power lines.
I'm saving these for another project.
I'll add more as we make progress.
  • There is an old dairy barn, built in 1925, on our property. It is 70 ft x 35 ft with 38 milking stations (19 per side). We just addded a 12 x 10 ft roll up door.
  • I can relate to this.We want to change our attached two car garage as well and the "While we are doing the construction anyways , why don't we add on to the house and put on an enclosed back porch area and ....." discussion keeps coming up. She doesn't think the 14 foot tall door will fit well with the bungalow roofline though, so we are back to just dreaming about the addition.
  • I bought a condo stoage unit 14 wide 50 ft. deep. 16 high. They have about 150 unit there owned by people mostly with RV's, Bath rooms, wash area for
    RV's, dump, air, fenced in with pass gate, night lighting, concert floors, cost me about $700 year for taxes and up keep.
    They started out at $32,000 went up to $60,000 now back to about $50.000
  • Looks like a good plan!! I know what you are dealing with when it comes to slopes and hills. My first home property had a steep back yard and a steep driveway. Sold that place about 8 years ago and bought a nice flat property.
    If it was me I would go with the 14' height.
