Halibut214's avatar
Halibut214
Finding a stud
I see a few posts where people used a stud finder on the inside with great success but has anyone used one on the outside? I know I have aluminum studs but have no idea if it will penetrate the fiberglass and plywood to see the stud.
Thanks
    Thanks
    I had to locate outside studs when I mounted the brackets on the side of my aluminum TT to hold my porta-bote.
    I actually used a studfinder on the inside, and then very carefully transferred the location of the stud to the outside. I measured things like distance from the edge of a window, etc.
    In one instance, I actually added a stud from the inside because there was no stud in a fixed location where I needed one. Then I covered it with wood trim.
  • RoyB wrote:
    Gentle tapping on the outside might come up with something as well...
    Very well, in fact. I located studs on the outside using a plastic-headed hammer I had from my transmission-repairing former life. Definite sound change when you hit a stud.
    Teach
  • RoyB's avatar
    RoyB
    Explorer III
    I have added a couple of shelf projects over the years from the outside using the molly bolt or spring wings idea. worked good... In this case you want to miss the studs haha... I like the MOLLY BOLT over the SPRING WINGS as when you remove the screw from the spring wing it all drops behind the wall...
    The thing that worked for me was to be able to mount the back board in its four corners then attach all your thing to the backboard. The backboard could be metal as well verses the wood you would use on the inside...
    The angles pieces and adapter plates etc you find currently used usually are just screwed into the trailer outside wall using plane ole self tapping metal screws and alot of sealent.. I have done this for additional CABLE TV type connection boxes or PVC Electrical junction type boxes where I was gaining access to the interior through the center of them with larger holes...
    I don't know about THOR but I do know you can contact JAYCO and provide them the VIN NUMBER of their trailer you own and they will immediately email you a PDF file with the information you requested. These are from their build packages...
    Roy Ken
  • Halibut214 wrote:
    I have a couple density type stud finders and will give it a try.
    How did I know someone couldn't resist with finding a "stud".
    If I still lived where we had dew I would not have had the need to ask but hopefully this will help someone as it is amazing how well this works.
    A molly bolt is not going to work on this. I'm not putting something on the inside. I understand the studs are not very wide but I need some meat to tie in to and it's the strongest thing there.
    I didn't even look at your profile to see you are from Arizona. I can imagine dew is not the norm for you. I wish the humidity would go away here. Good luck
  • Halmfamily hit it right. Wait for mother nature to reveal the studs.
  • I have a couple density type stud finders and will give it a try.
  • RoyB's avatar
    RoyB
    Explorer III
    The studs are not very wide in the RV's even if you find one... You get the best results by using something that spreads out when you tightening it up...
    We have great success on the inside using the MOLLY BOLTs to do this...
    It really works great to use the moly bolts to support a large piece of 3/4-inch plyboard and then just use regular screws etc to hang your items to the large section of wood...
    Much like this pictorial suggests...
    On the inside would look something like this with a large backboard installed to mount your heavier items like LCD TV's...
    Roy Ken
  • Watch the dew patterns in the morning on your outside walls, you'll see the studs. Mark and measure where they are at the measure inside.
  • IF it is a 'magnetic' type stud finder.........NO
    If it is a 'density' type stud finder..........Yes
