RoyB
Jul 28, 2015Explorer II
Does your factory HDTV Antenna look like this... This is about as good of a roof mount RV antenna as you can get... This antenna is a crank-up and can manually rotated from inside your trailer with a hand crank in the ceiling...
What kind of antenna did you have...
We pick up all kinds of full blown Digital high Definition TV signals using this type antenna...
Even you find out where the so called studs are they won't be alot of help for you. The RV studs are 1-inch by 2-inch deep or so... They will probably be aluminum studs You need to use the MOLLY TYPE BOLTS that spread out behind the walls.
Roy Ken
Roy Ken
44,056 PostsLatest Activity: Jan 12, 2020
