Butch50
Sep 16, 2013Explorer
I also have the wireless controller but I have had problems with mine. When I try to go down in air most of the time they just set there and after numerous tries it finally airs down. I also have never been able to get one any of the present buttons to set correctly. The instructions for the unit leaves a lot to be desired on the usage of it unless they have changed the instructions over the last couple of years. I also have a leak in my right side and I have yet been able to find it. I squirt soapy water everywhere and still have not found it. When I want to put more air in the bags I set the pressure and then sit and wait for it to decide if it is going to air them up. I have put 30 PSI on the remote and then it starts to fill and then it might stop at 25 and then I have to put it at 30 again and after several tries I'll finally get them up to the 30 that I wanted.
I hope you have better luck with your system. It does save a lot of getting out and airing up the bags but I wish I could of installed the one with the gauges and manual setup but with my truck with the KR console there is really no place to put the gauges and switches to run the compressor. I don't change mine that much so I'm thinking running some lines so I can adjust mine with my compressor. I don't change them that much so unlike you with all of your different trailer I can see where it would be a hassle for you.
