IntuderOwner
Aug 11, 2017Explorer
Well I pulled the trigger and ordered one from Costco. Received it two days later. Inboxed it and oiled it up and checked out the choke cable that some people had claimed was an issue for sticking in the full choke position. It was okay . Loading the crankcase with oil was a bit dicey as the instructions did not say how much oil to use. ( slightly less than the quart bottle supplied) so I had to keep pulling the funnel and putting in the dipstick. Fired up on second pull and ran great. A little noisier than I was expecting but manageable . I plugged the rv in, and it ran everything , I shut everything down and started the AC and had to run the fan first then kick the AC on and it ran fine,
It finally kicked out on overload after firing up a bunch of stuff but I can't remember the combination of stuff that kicked it out. I noticed the power cord getting warm after running with AC on for about 2 hours. Once I finish the 5 hours breakin I will post back my final comments
44,068 PostsLatest Activity: Jun 10, 2026
