dbbls
Jun 24, 2014Explorer
Normally one tank supplies all the propane appliances in the unit. There should be a regulator between the tanks that will switch from one tank to the other when the one in use runs out of propane. You must remove the tanks to have them refilled. I suggest you drive the unit to a propane dealer and he can explain how it works and refill your empty tank.
44,056 PostsLatest Activity: Jan 12, 2020
