kohldad
Aug 24, 2014Explorer III
Very glad your trip went well. Learning to level get easier, but no matter how could you get, you will always find a site that takes forever to get it right.
I never use the jacks once the camper is on my truck. All I carry is two 6x8x10 blocks, four 2x6x16", and a stack of eight leveling blocks. I use two 2x6 beside each other because I got tired of my 2x12s splitting in half after they dry out. I can use the block in any direction I need and have even learned how to use the leveling blocks on top of the boards for increase height. My wife was real nervous the first time I used a block on the 10" side and three leveling blocks on top of it. I pull up enough that the 2x6 becomes level with one end off the ground. But I explained that in 4wd-lo and granny gear plus the e-brake on, the truck wasn't about to move. After a couple of hours of seeing how steady the truck was, she quit worry about it. I'm also not paranoid about making sure the suspensions is all compressed the same. I have no problems having an axle compressed more on one side than the other. After all, that is part of the reason of the suspension.
With regards to the step being high, just turn around and it would be closer to the ground. May also have been easier to level.
44,027 PostsLatest Activity: Mar 05, 2025
