DownTheAvenue wrote:
Some refrigerators have a high humidity function which is a small heater in the door frame of the refrigerator to keep moisture from forming. If yours has this and that switch is on, you will consume an alarming amount of battery reserve in a very short time.
Anyone hear an echo? :W The OP has a 2017 model year trailer with a Dometic DM2652 which will NOT have any switch to disable what you call the
"high humidity function" i.e. climate control heating element. He has to either cut the appropriate wire OR add his own switch as I detailed earlier on Page 2 of this discussion. ;)
