Devocamper
Jul 24, 2017Explorer
mike/kellie wrote:
Devo, nice report! I ordered 2 fans last night. Just removing the upper panel cooled that back cavity nicely. I see the factory placed single fan and will eliminate that. I do like the other windows seen on other rvs. Ditto on the generator but our solar keeps things up and running. Did you get the double couch? That is what I would want if starting over. Our build was 2014 and there have been many improvements. Host sent me the track and hardware for the bath radius panel door. Good factory support with just a phone call. Enjoy
Thanks, We did get the double couch with the high low table in the pecan wood, we had ordered the cherry but host changed the model year and started the new decors before ours was built , we actually like the pecan a bit better than the cherry, They also added the black tank flush as standard for 2018 as well as the new graphics which I am sure you have seen. On ours the fans were an easy change the bracket was there for two 92mm case fans I would have liked to go bigger than the 92mm but did not want to start drilling holes in there and have the chips falling down the wall into the fridge controls and wiring, so far the 92 mm size fans are working well but if I were in really hot weather all the time I would look for some larger fans to move some more air but for now I am good , what cfm fans did you order? it is hard to find much more than 50 cfm in anything that's quiet. you should also check your inline fuse mine was a three amp which is more than enough for the two fans I installed but once you cant hear them the only way you will know if they failed if buy poor fridge performance, or a really hot closet, I am a little surprised at how warm or hot the closet gets next to the fridge I took a temp and the wall is 100 degrees but no way to vent the closet so more air out of the fridge should cool off the closet .
Thanks
Mike
44,071 PostsLatest Activity: Aug 16, 2026
