mike_kellie
Jul 24, 2017Explorer II
Devo wrote:Mike, there was an article in Truck Camper Magazine a couple months ago and a guy named Charles put 2 low speed, high volume fans made by AeroCool. Specs say 76 CFM at 18 dBA at 800 RPM. These are mounted to the panel and used to exhaust air and not move air across the fins. Can't hear them, don't worry as they emit a soft blue light while on.
if I were in really hot weather all the time I would look for some larger fans to move some more air but for now I am good , what cfm fans did you order? it is hard to find much more than 50 cfm in anything that's quiet.
He pitched the mount to help pull hot air and exhaust it through the ports of the plastic cover panel and claims it's helped a lot. To keep up with you guys and the newer Hosts, I pulled out my fireplace and radio and moved my invertor into the basement along side the transfer switch. I was getting a buzzing hum from the invertor fan when things got warm and now in the basement, things are pretty quiet.
44,071 PostsLatest Activity: Aug 16, 2026
