Devocamper
Jul 26, 2017Explorer
Bedlam wrote:
I'm over 13' but under 13.5' - Deck height is 3.5' unloaded. The vent covers are not higher than the air conditioner shroud.
Bedlam
Thanks I am waiting to get on some level ground and have a ladder available to check my height and know for sure how tall I am , wanted to ask you if you have had any trouble with your safe t alert combo LP/CO alarm my lp alarm has gone off a few times thought at first I was drawing some propane in from somewhere because it was happening when I turned on either the bathroom vent or the rear fan. I checked for leaks can not find any then thought maybe it was a low voltage thing with the detector because we were dry camping and the batteries may have been low but then it went off a few times yesterday at home with the TC plugged in and the last time right after I opened the slides and batteries at 13.6 on charge and nothing on that would be drawing propane so I am thinking its not low voltage maybe just a bad detector. I have it out in some fresh air and both tanks off and will see what happens when I put it back in just wondered if you had any issues with yours ?
Thanks
Mike
