Devocamper
Jul 26, 2017Explorer
Thanks it was strange that the last two times the LP detector went off none of the appliances were running and the slides were closed but the first time the hot water heater and fridge were running on propane and it went off when I started the bathroom vent fan but the last time it went off the camper was closed up nothing running. I opened the slides to get in and the lp detector went off again, I am going to check everything with a sniffer meter/tester even thought I haven't smelled anything and no leaks were found with liquid leak check on all the fittings I can get too. Will update here if I do find anything .
Thanks
mike
Thanks
mike
