DSSAMP
Jul 27, 2017Explorer
The wires they are talking about are in the cabinet next to the steps. You need to life up the carpet and board that is on the bottom of the Cabinet. There is one screw about 1/2 inch in from where the door opens, must remove that screw. It's kind of hard to find in the carpet but it's there. Once you lift the board, you can see all the wires and water pipes. The red wires are the ones they are concerned about. Took 2 clamps and screwed to the floor, problem solved.
Hope this helps...
Hope this helps...
