thinksnow66 wrote:
Hooked up the trailer to our expedition for the first time and did a 25 mile test run on the interstate. This is the first time I towed anything big with the Expy. I usually use my F250, HUGE difference. Towing a 30ft trailer with an Expy difinetly has a pucker factor. There was a bit of a bounce. I was able to maintain my lane, but that surge / bounce effect leaves me feeling uneasy. Is that normal when towing a TT with a half ton vehicle. The back of the truck saged a bit, and nose was up slightly. I know the expys always sag a bit, even with the WD hitch because of the independent rear suspension. Do I need to crank up the weight distribution bars by one more link on the chain? I'm on the 5th link now.
Are you using the same hitch for both TVs? The settings will most certainly be different.
You need to go thru the setup procedure again for the EXP.
If you are not going to get another hitch, then record the setups for both TVs so you can quickly reset it to what TV you will be using.
