Family-of-five's avatar
Sep 09, 2020
first time out
Hello friends This weekend will be out first time out in our new open range light 31bhs. I only have 15 amp to it in the driveway to keep the battery charged and run lights . just wondering what to check for after hooking up to 50 amps. I know to test the water heater on lp and electric.Look for leaks underneath.Test both ac units and furnace.Can you offer some small things I might overlook?
    If you have not packed the wheel bearings in the last year, do so. Carefully check tires for air maximum air pressure, cracks etc. Put about 30 gallons of water in your fresh tank. Make sure battery water is filled up, check for any battery post, cables for corrison.
