pmlevine wrote:
The Nissan Frontier GVWR is 5815 lbs.
The Nissan front axle GAWR is 3296 lbs, the rear axle is 3331 lbs.  With travel trailer loaded, I estimate the tongue weight to be around 650 lbs.
The Micro Minnie dry weight is 3705 lbs. The front end of the Micro Minnie is curved, and hopefully will help on wind resistance.
Oh boy, here we go. :R
First of all, dream on about that so-called "curved" front wall on your trailer - travel trailers ALL
have a curved front wall and the only difference that might be noted is if it was compared to a perfectly vertical wall.  NO travel trailer front wall is perfectly vertical so any minor difference in curvature between trailer front walls will have
zero impact on your ability to tow any TT with your Nissan.
Secondly, your V6 truck will be working hard towing this trailer, count on it ... and that will be reflected in it's fuel mileage returns which you can bet won't be any better and probably worse on average than what a properly geared 1/2 ton would get towing the same trailer.  When it comes to towing a barn door at highway speeds it's all about grunt under the hood.
So now you know your truck's GVWR, what you
don't know is what it actually weighs sitting there with a full tank of gas ready to be hitched to a trailer.  To determine this fill the tank and with the weight distribution mounted on the truck (and even spring bars in the back) go weigh the truck.  If you're in it at the time subtract your weight from the scale reading - that's your truck's actual real world curb weight, ready to hitch up to a trailer.  Subtract that number from it's stated GVWR and the difference will be it's
actual real world payload capacity.  That's the number you're going to use to account for the weight of all people in the truck, all cargo you may toss into the truck, plus any gross tongue weight transferred from the trailer to the truck.
With a factory dry weight of 3705 lbs you can bet the trailer's actual weight as it sits there with any options & accessories it may have, a battery, propane in the tanks, water in the water heater tank, and some reserve water in the fresh water holding tank, will be several hundred pounds more.  I wouldn't be surprised at all to see this trailer's actual GVW hit
at least 4000 lb
before you add any of your personal gear - clothes, bedding, food, camping equipment, etc, etc, etc.  Loaded and ready to camp I doubt you'd be as heavy as 5300 lbs but it certainly would be at least in the 4500 to 4700 lb range even if you're
really careful about what you load into the trailer.  14% of 4700 lbs (as an example) is 658 lbs and dollars to donuts I'd bet that's approximately the gross tongue weight you'll be running with this trailer.  That's weight your truck has to accommodate within it's payload capacity ... exceed that and you're sure to also exceed it's GRAWR (Gross Rear Axle Weight Rating).
Not only are you expecting your V6 with it's rather modest HP and torque ratings to deal with twice the weight when towing this trailer than it normally does but you haven't even considered it's axle ratio and transmission characteristics, both of which are vitally important.  I run GM's ubiquitous but non-tow friendly 3.42 axle ratio coupled to an older wide ratio 4-speed transmission in my Avalanche ... works OK but is hardly sterling and I would be far better off with a 3.73 axle ratio coupled to GM's more recent narrow ratio 6-speed transmission.  As far as I can tell from what you've told us so far you haven't even considered this but believe me these details make a HUGE difference in the ability of your truck to tow.  Unfortunately most off shore vehicle manufacturers don't offer different axles whereas domestic manufacturers (GM, Ford, Dodge) do, because those trucks
are designed to tow.
Unfortunately, you have what you have and since it seems like this is a done deal the best I can do is wish you well but with the prediction it will only be a matter of time before you,
like many before you, will be looking for more truck. ;)
