Boon Docker wrote:
Still can't quite figure how a trailer weighing 3800 lbs with a tongue weight of 350 lb (9 percent) when loaded correctly to 4800 lb can increase the tongue weight to 14 percent of the trailer weight. It should still be 9 percent of the total trailer weight.
Regardless of any stated factory dry tongue weight it's up to every owner to ensure gross tongue weight falls within 10% to 15% of the trailer's gross weight, loaded and ready to camp.  While 10% may be within the "recommended" range most would find that awfully light, with the trailer exhibiting a tendency to sway with so little tongue weight.  I personally consider 13% to be minimal but as I said earlier I prefer even more as I know from experience that even more leads to a much improved towing experience.
