profdant139's avatar
profdant139
Explorer II
Jul 08, 2018
First time using TT as a lifeboat: it has A/C, house doesn't
We have long planned to use the trailer as a "lifeboat" in case the house was damaged or destroyed by fire or earthquake. But when the temp hit 113 degrees the other day, we had to hide out in the trailer (parked on the driveway) as our refuge from the heat.
We live in coastal Orange County, Calif., where it is usually in the 70s -- the house has no air conditioning because we almost never need it. But this heat wave was off the charts -- the temp in the house was around 90.
So I plugged the trailer into my 25 foot 12 gauge extension cord and a heavy duty "dogbone," and used my heaviest circuit in my garage. Success! The air conditioning worked perfectly in the trailer -- we had never tried to run it at home.
I later checked the extension cord and the plugs -- they were warm (but not hot) to the touch.
I'm guessing that lots of folks have done something similar, but this was a first for us.
    My 31 yr old Carrier A/C here at the house finally cried uncle after 3 recharges over the last 5 yrs. Naturally it waited until this recent heat wave here in the east to fail so last week was pretty miserable in the house. As luck would have it our guests visiting from Downunder had just left so our trailer which we had used to take them camping was still sitting here on the driveway. My recourse to survival in this extended heat wave was to do exactly what you did - run the trailer A/C. Since my closest drop in the workshop is only 15 amp I made up an adapter so I could instead pull from one of the two 30 amp legs that normally feed the house dryer. It works just fine but before I'm chastised once again here on the forums NO I'm not recommending this as a solution for everyone, just saying this is how I solved the issue for myself. :B
    If the house service into which you plugged your rig is 20 amp (common in the US but not here in Canada) then I would expect it to work just fine assuming nominal voltage wasn't excessively low but a 10 gauge extension rather than a 12 gauge still would have been a better choice. In my case the 15 amp drop in my workshop will power my Dometic A/C but even with no extension cables involved voltage drop when the compressor starts is significant and better to be avoided. My 30 amp adapter solution does just that so I'll keep it for future use, if ever necessary.
  • “they were warm (but not hot) to the touch.”
    They were warn because it was 113! lol 112 in Glendale.
  • Last week we had a family outing at the State Park and while we were playing in the 80 plus heat and humidity, my dog and my daughter's dog, two large Golden Doodles, were perfectly content to sleep in the comfort of the TT AC for a couple of hours.
    Needless to say they were refreshed and ready to play when they woke up. :)
  • We have done similar when the A/C was on the fritz. Also, we used the TT when tornados knocked out power for over a week--we boondocked using our generator. Also, we were able to take hot showers and cook on our RV stove while waiting on power to be restored.
  • Someone already PM'd me asking about the circuit. (That was fast!) . It has a 20 amp circuit breaker. Obviously, I shut off all other devices on that circuit, to make sure the A/C would start and would run.
