Heap64 wrote:
It appeared the truck and trailer were not both level side to side. The truck looked unlevel side to side and was probably making the hook up harder? Eventually he had a bunch of planks and I saw later he had left with the trailer.
For those of you with one, is this probably an inexperienced user, a bad hitch-up situation or something you have seen? The man looked a little older, but he had some help.....
It's actually quite easy. All he needed to do was to adjust the tension bar jacks so that the hitch opening was at the same angle as his truck.
