Gazzer wrote:
Folks, you don't need to lube your stinger. Simply measure the top of your stinger in your tow vehicle without a load on it and record the height. When unhooking, simply raise via the tongue jack to match the recorded height, Loosen the jacks to where the bars move freely, unhook and idle forward, it's that easy!
BTW, if you know anyone that is interested in a high end TT with ProPride, check this out; http://portland.craigslist.org/wsc/rvs/4567624233.html
Cheers,
-Gaz
While lubing isn't mandatory. It doesn't hurt. Lubing will allow the stinger to slide in easier. There is a learning curve to using a PP or HA. In the end "Practice makes perfect"
