Gazzer wrote:
Folks, you don't need to lube your stinger. Simply measure the top of your stinger in your tow vehicle without a load on it and record the height. When unhooking, simply raise via the tongue jack to match the recorded height, Loosen the jacks to where the bars move freely, unhook and idle forward, it's that easy!
Cheers,
-Gaz
agree .... after following our daughter towing her camper and watching the sway, I had a ProPride installed .... as others have noted, the difference was remarkable .... she uses a
Trailer Alignment Magnet Hitch Line Up Mirror to line the stinger up with the receiver .... to make it easier to see, we spray painted the stinger John Deere yellow and put a strip of red reflective on the top of the receiver .... doing so really helped .... as noted above measuring the unloaded height of the truck's receiver and returning it to that height when unhooking has really made it much quicker/easier
Jim
