Trevut's avatar
Trevut
First Timer - Water tank reading empty after pump turned on
Hi all,
This is my first time taking my new trailer out. I filled the fresh water tank and the indicator light read full for the fresh water tank. I then turned the pump on. When the pump turned on I could hear water running, and I assumed water was running into the lines. As normal, the water pump kicked off after the pressure built up. However, my fresh water tank is now reading empty. How can this be? The blank tank is reading empty and the gray tank is reading empty. I turn on the faucet and water does come out. I've looked all around the trailer and no water has drained out that I can see--there are no wet spots anywhere under the trailer, and nothing is dripping from the trailer.
I wouldn't think that this much water could fill the lines, but is that what happened? Any help would be appreciated.
