DaDubs wrote:
I have the gvwr package. It adds 700lbs of payload above a stock F150. I was actually shocked at how little the truck squatted after hitching up.
Yeh, but your axles are the same as some other trucks with only a 7200 lbs GVWR.
Standard axles on Crew Cab 4WD short bed truck are Front = 3750 lbs, Rear = 3850 lbs.
Standard axles on Crew Cab 4WD standard bed truck are Front = 3900 lbs, Rear = 3850 lbs.
20" wheels will bring the 4050 lbs Rear Axle. Heavy options will bring the 3900 lbs Front axle on short bed trucks.
If it's an Ecoboost Crew Cab 4WD with short bed, it will have a 7200 lbs GVWR. If it's a 5.0L it will have a 7350 lbs.
If it's an Ecoboost Crew Cab 4WD with standand bed, it will have a 7350 lbs GVWR. If it's a 5.0L it will have 7350 lbs as well.
Max Tow package only adds a 4050 lbs axle over the standard 3850 lbs axle. Max Tow package components weigh 75 lbs. You net only 125 lbs!! Yet Ford boosts the GVWR up by 450 lbs (7650 lbs with short bed or 7700 lbs with standard bed). The added payload is artificial but will help with a legal claim should you need it.
HEAVY DUTY SUSPENSION PACKAGE on Ecoboost or 5.0L Crew Cab standard bed truck: Front axle = 4050 lbs, Rear axle = 4800 lbs, GVWR = 8200 lbs.
If you want payload get the Heavy Duty Suspension Package otherwise you'll run out of axle capacity way before you run out of tow capacity with standard Tow and Max Tow packages.
