travelandy wrote:
I'm wondering if there's anything special we should be looking for beyond the usual checks for leakage, water damage or soft spots.
Especially with a trailer of this vintage you'd want to pay particular attention to the running gear - tires, brakes, and bearings - meaning the current owner should be able to provide proof as to when these were last attended to. If he/she can't then you'll want to factor that into your negotiations. Learn beforehand how to read the manufacturing date code on the tire side walls as any manufactured much before 2010 or perhaps 2009 are in need of replacement regardless of how "good" they may look ... bearings and brakes should be done at least every couple of years. I'd also want to know the expiry date of the propane tanks and would probably plan on replacing all the rubber lp hoses and the regulator. Good luck with it! :B
