blofgren
Jun 21, 2015Explorer
Showme 5vr wrote:
We are in Branson and the trip down was GREAT! The EB worked as advertised, used it on "Full" on the way down may try "Auto" on the way back. The brake controller worked just fine also. The 5th wheel is a little nose high so I checked temps of the hubs and tires with a laser thermometer. The tires and hubs on the rear axle were about 5 degrees higher than the front axle. The truck pulled perfectly. That 6.7L and 6sp tranny is awesome.
I knew you would be happy! They pull very well don't they?
I have the same issue with the trailer being nose high. Luckily it has adjustable suspension so I'll have it raised which should minimize the problem.
44,059 PostsLatest Activity: Mar 18, 2026
