mike_kellie
Jun 29, 2016Explorer II
I already have an idea about routing the the waste opening to the underside of the slide when it is open. It would still require an access door in the sidewall of the slide to access the valve.
BTW: Did you know Host repurposed a battery box for the black dumpeople
Sorry trying to cut and paste from phone. I didn't know that! 2 things (1big) that need to evolve is a better track to hold the folding wood door to bath. I've cracked the track because the hardware is a small diameter carrying the weight of the door. If the door bounces while traveling, it will do just that. Also need a storage tube for waste hose that will fit the bigger diameter fittings. I'm seeing secure fittings required at parks these days.
