Bedlam
Jul 03, 2016Moderator
Spearfisherman71 wrote:tad94564 wrote:
As for the curved sliding door in the bathroom - if you do not have the stainless steel metal track, call Host and demand they replace/install it. I broke 2 tracks, and re-hung the door using hinges, before Host finally found a proper solution and installed it.
Ended up at the factory 3 times (long story, it actually ends up the best and fastest way to get things fixed here in SF bay area..) and they fixed a whole slew of problems.
And yes, I knew it was battery box, installed up side down for the black waste valve. It's also were they installed the tank flush for us.
Looks like my previous post didn't go through, hopefully this isn't a duplicate. I was wondering if I could easily access the black tank to add a flush and the seelevel gauges or would it be too much trouble and should ask host to do it in the build?
Since the bathroom sink and toilet both go to the black tank, I wonder if you really need a black flush outlet? I won't argue that having one would be more convenient but maybe not a necessity.
