Spearfisherman7
Jul 04, 2016Explorer
tad94564 wrote:
The black flush makes it really easy to flush the tank; there is 90 degree bend at the valve that makes getting water back into the tank impossible. they placed the flush head under the sink area, so it when it runs clean, I know it's pretty dang clean.
As for the seelevel gauges, I had them also installed at the factory; but you can easily access the tanks if you are handy enough afterwards. There is a cover in the dinette that allows access to the front of the black tank, and there is another cover in the basement you remove and you can access to the grey & fresh water tanks.
So the tank flush sounds like something I would want to get the factory to install, is that right?
