Peacester wrote:
Anyways for those that Don't know I'm fixing up a 79' Wilderness Camper. My issue right now is that My water Heater Lines Broke. On the back of my water heater I have two grey lines coming out ...
Grey water lines, along with this being a 40 yr old camper, likely means this is QUEST tubing, not PEX, and if that's the case you'll find joining the two problematic at best since QUEST is slightly different outside diameter than is PEX. Normally one would suggest using quick connect fittings such as Sea Tech or Sharkbite but they're made to connect PEX tubing together ... a problem for you to be sure. That said, do you really want to try to rely on a 40 yr old water heater? ... perhaps time to replace it with a new one. ;)
