DiskDoctr
Sep 03, 2013Explorer
Be sure to check your walls and roof if the leak was high.
Watch when cutting the floor, as ductwork, water lines, propane lines, water and waste tanks, even electrical wiring may be present near where you are cutting.
Is the flooring wet and soft, or does it have black or rotted wood?
Be aware, it is also common to have soft spots in some campers over things like the water tanks and such- due to poor bracing.
44,068 PostsLatest Activity: Jun 21, 2026
