MFL
Jan 11, 2019Nomad II
After owning several TTs, which did tow well for me, I switched to fifth wheel models. I do think FW towing is a much better experience. You have enough truck for towing/carrying a FW, so might be something to consider. While current FW is heavier than the previous FW, it is more aerodynamic, and tows just as easily, with about same towing MPG.
I do think aerodynamics has something to do with one towing better than the other. As far as weight, once moving, rolling down the road, 1500 extra lbs, should not be a huge factor. If you had a brake dragging/over tightened, to the point of heavy towing feel, it would have been smoking, lots of stink, so would have been very obvious.
Jerry
Jerry
44,070 PostsLatest Activity: Jul 01, 2022
