What would be the best way to tackle this floor rot? The last 6 inches of plywood is rotten on the back. Can I cut a new piece of marine grade plywood and slide it in to replace the rotten wood? I ...
Thanks Led, I am in the process of figuring out which wood hardener I want to buy, then once I get that injected I will put an epoxy putty over the wood so the screws can have something to bite into, or atleast that is the plan so far.
The wood is good and dry, I have been keeping the affected area covered with tarps, I might even run a fan on it before doing the harder.
