mellow's avatar
mellow
Floor Rot
What would be the best way to tackle this floor rot? The last 6 inches of plywood is rotten on the back. Can I cut a new piece of marine grade plywood and slide it in to replace the rotten wood? I will have to remove the waste tank, any easy way to do that?
  • Thanks for the reply eric, nice to hear it isn't to bad of a job, since the rot is only the last few inches on the back I might very well try this angle iron idea, it seems like a logical solution.
  • Talked to a friend who is in construction, after showing him the pictures he said he would do 2 pieces of angle iron, one steel for the bottom and screw it to that frame piece then another aluminum piece to the back so I can attach the skin to that.
    If I did it that way I wouldn't have to pull that wood out and the angle iron would act as a support, I might just put some epoxy into that rotten wood to hold it together.
  • I just recently tackled this same thing along with much much more! lol....I totally gutted and re-did what I think is a 1972 Coachman knight. Anyway yours actually looks pretty good. The easiest thing to do is cut out all the rot until you reach solid wood and then once you pull up the rotten wood you will see how the floor is framed together. After removing the rotten flooring and frame it's pretty easy then to just tie into the good stuff and lay down a new piece of floor. As far as the tank it's hard to see exactly in the pics but you may find you won't have to disturb it at all to replace the floor. Good luck and just dig in. It's really not a bad job.
