SDcampowneroper
May 09, 2021Explorer
Yes I have fixed a foam core floor in our 87 Award. I drilled from above and below just through the ply, then injected foam conpatible adhesive. Worked good, but we did have to refloor inside.
You could try doing it by drilling up through the bottom ply and foam then injecting, wait to set then drill again only through the underside ply to inject again. A nozzle to make certain the adhesive goes up to the top, and does not spread into the lower area is something to consider.
Test --- Try your adhesive on samples so you know amount and compatability. Cant have a adhesive that foam does nt like. Too much adhesive could cause the floor to swell. A flexible urethane minimal expansion foam should do. Small squirts, close together. Get some 1/4" ply, foam and experiment before you try it out on the camper.
44,056 PostsLatest Activity: Mar 02, 2026
