KimberlyHoward
Aug 31, 2021Explorer
GrandpaKip wrote:
When I repaired an area by the door on a previous trailer, I used some 2x6’s as the foam was 1/12” thick. Glued and screwed them to both top and bottom plywood. Very solid.
Thanks for the feedback. My foam is several inches think. It's a lightweight camper, so the subfloor is thick foam sandwiched between two very thin pieces of plywood. We should have completely removed the foam sections and replaced with new, but we didn't realize such a small divot would create so much give. The new plywood floor is in place and painted, furniture re-installed, and new LVP installed over it. I'm looking for a "back fill" option for the two small areas that doesn't require removal of everything we just put down.
