ogrer wrote:
Thanks
Found the screws 2 on the inside top, 5 on the outside top and the two toe nailed under the material and the bottom.
The window is r & r with new tape. The window sill showed no signs of water entry
Weepers are clean. My hands are now really grimy. Bigfoot used black butyl tape. Next time I will wear gloves.
Bob
The windows in the overhead bed area can leak. The water will follow the foam seams then finally work it's way down.... Who knows where it will end up.... I had an over head light leak years ago on my BF.... Caught it early but the leak was inside the side bed cabinet, the center light was the one that was leaking.
Jim
