jimh425 wrote:
For those using Horse Stall Matt, how did you cut it and do you have a heavy camper?  In my case, each corner would likely have 1000 lbs or more on each jack.
I used a battery powered circular saw with a basic 5" wood blade on the first set.  The second set I found the mat at an estate sale and the only thing I could find there to cut them was a hack saw with a metal blade.  Took longer but got the job done.
As far as weight, they support My 20,000 lb. DP.
The second set was bought with the idea of parking on them while in storage.  I always forget to put them out so still haven't used them but my brother has used them a few times under the tires of his TH to level when he forgets his blocks.
