toedtoes
Feb 14, 2019Explorer III
Regardless of whether the pedestal is 50 or 30 amp, you ONLY have 30 amps max for use in your trailer via the power cord.
If you install a 50 amp pedestal, you could use a 50 amp male to two 30 amp female splitter. Plug your trailer cord into one 30 amp female end and a 30-20 amp dogbone into the other and use that to plug in an electric heater, etc., separate from the trailer system.
Outside of that, the only benefit of adding a 50 amp instead of a 30 amp is if you decide to get a new RV at some point that has 50 amp.
Doing a combo pedestal like Bobbo indicates would provide for all three of those scenarios.
44,068 PostsLatest Activity: Jun 01, 2026
