Reisender's avatar
Apr 04, 2022
For those towing with Teslas. Super charger tips. Thanks
Hi Folks. For those that are towing with or plan on towing with a Tesla, here is a little info on charging at Superchargers that don't have a trailer spot at the end of the row or a pull thru. Still very common and pull thrus and trailer spots have only started to show up in Superchargers that have been built in the last couple years, and sometimes even on new ones like the one in our home town.
So count on using 3 spots. It looks like 4 spots here but that is because someone was parked at the end of the row and I didn't want to crowd them for the sake of a picture.
Anyway. This happens reasonably often. If the supercharger is quiet then this is acceptable. If not expect to unhook the trailer which really isn't that big of a deal. Tesla is building more and more stalls suited for small trailers but as more and more people tow with their Teslas they are going to need a lot more.
Tip. You don't have to get too close to the curb as you swing in. A couple feet is fine. The cable easily reaches that far and you can pull far enough ahead to not impinge on the 4th spot (like I am doing in this picture). :)
Obviously charging at the campground is still the easiest method, but we do lots of dry camping and this is still a reality sometimes. The joys of being a pioneer.
Safe travels all.
JMHO. Cheers.
  • “So count on using 3 spots. It looks like 4 spots here but…”
    I wouldn’t block two or three charging ports while using another to avoid unhooking. Similar to cars taking RV/truck spots at roadside rests. Very inconsiderate.
  • jdc1 wrote:
    F150 Lightning EV and a 20+ trailer may be another story?
    True. But this is a supercharger so it wouldn’t work anyway.
  • jdc1's avatar
    jdc1
    Explorer II
