rjstractor wrote:
BenK wrote:
Push button is not able to switch on the fly much above 3-5 MPH
I don't believe that to be true at all. I've owned vehicles that could shift on the fly at 50+ mph without issue. Now, if you're referring to shifting into low range, this has to be done at a near-stop regardless of shifter type.
Totally agree with rjstractor. I've owned two trucks with the electronic controls for a combined total of about 250,000 miles with zero issues. Part of that is probably due to actually using the 4 wheel drive system periodically.
Another point is that it's easier (as in "safer") to engage 4 wheel drive from a knob on the dash versus leaning down to the lever on the floor, especially if you do it as often as I typically do.
