rjstractor wrote:
BenK wrote:
Push button is not able to switch on the fly much above 3-5 MPH
I don't beleive that to be true at all. I've owned vehicles that could shift on the fly at 50+ mph without issue. Now, if you're referring to shifting into low range, this has to be done at a near-stop regardless of shifter type.
There are no synchros to help you get in to low range. Neither my Ford or Ram suggest shifting in to low without being at a complete stop. If you have manual hubs locked or automatic hubs, you can shift between 2wd and 4wd high at speed as long as you are going straight and you do not have wheel slip at the moment. Typically, I shift the automatic into neutral prior to shifting the transfer case and then shift it back to drive.
