diftw
Sep 13, 2016Explorer
agesilaus wrote:
Do it yourself it takes about 30 mins max. But watch this video first:YouTube
But, and this will save you some money. Do not use a wrench on the chassis filter under the drivers seat. Get a big enough strap wrench to fit around the filter and use that to remove and re-install the housing. Using a wrench will wring the bottom of that housing off.
BTW it isn't that messy if you open the drain on the chassis filter and give it 30 mins or so to drain the fuel.
If you are getting the oil changed at someplace that doesn't work on diesels make sure they are using the correct oil.
What size strap wrench do you use? Any recommendations from Amazon?
44,056 PostsLatest Activity: Feb 28, 2026
