ford_truck_guy
May 04, 2016Nomad
leftybj wrote:
I just bought a new F350 and it has a built in brake controller. The owners manual says that you need to make sure that if you have an electric over hydraulic braking system on your trailer that it is compatible with the Ford controller. I don't have disc brakes on my current TT but would like to get them when I trade. Does anyone currently use electric over hydraulic brakes with a Ford TV and also, is there a good source that lists compatible systems? Thanks for any insight you may provide.
I have a 2015 F-350 and pull a fifth wheel , I just swapped my new drum brakes for the Titan Disc complete set..
Once you swap to the discs ,just go into your dash settings and pick electric/hydraulic and hit ok.. Going to the disc system is like night and DAY.. unbelievable difference in stopping. You will NOT regret it. Some of the systems need a CAM module inline to help the actuator..
44,066 PostsLatest Activity: Jul 25, 2018
