Nunyadamn
May 05, 2016Explorer
I think they are talking about surge brakes. Most travel trailers are full electric - magnet is energized to pull in the pad to the drum or disk. To figure out what you have, check to see if you have a hydraulic reservoir - I doubt you do. Usually you will find electric/hydraulic brake systems on boat trailers. They have an electric pump to send the hydraulic fluid to the brakes. I suspect you will be setup correctly with your truck brake controller and your travel trailer. See the setup for adjusting for electric brakes.
44,066 PostsLatest Activity: Jul 25, 2018
