billtex
Oct 08, 2013Explorer II
diver...where did you hear that about CA not allowing campers off the truck?
I think I would look into that a bit further before I got too excited.
I am sure plenty of Folks here could confirm/deny that...
As far as a 1/2 ton versus an HD truck for a TC?
You could "get by" with the 1/2 ton...but it will not hold up as well in the long term with that kind of use.
If you already owned the 1/2 ton...then sure...try it.
You have the luxury of buying both at the same time...no one ever complains they have too much truck. The cost difference between the 2 is likely negligible...and you will probably have to upgrade components on the 1/2 ton before you put the TC on; tires/wheels, suspension.
I would not buy a 1/2 ton intentionaly for the purpose of hauling a TC.
You should take a look at this thread going on right now...pretty much sums it up.
Bill
p.s. If you are asking about hauling TC's...be wary of TT advice...2 different games.
Bill
44,056 PostsLatest Activity: May 04, 2014
