RoyB
Apr 04, 2014Explorer III
I always look for a RUBBER FITTING or GROMMET I can puncture a hole thru it to get the cables though. Once done then I will use RTV to seal the hole back...
I'm sure if you look good around the firewall you can several factory installed rubber hole fillers. Just check both sides before you puncture through with a sharp tool (i.e. Screwdriver). Don't want to hurt something behind the wall so to speak.
Roy Ken
Roy Ken
