audincli9's avatar
audincli9
Ford Exp - Jayco WH 23MBH - Dream Combo or Bad Idea?
Hello,
I am considering purchasing a TV/TT combination and allowing for budget constraints and family size have narrowed the choice down to 1 TV and 2 TTs. We missed the whole young family camping/RVing window and so now are attempting this activity with 4 boys, 2 of them older teenagers and 2 of them almost teens. This poses certain problems, the least of which is that not everyone can sleep in the dinette, at least not without a lot of wailing and gnashing of teeth. But I digress…
I've read a number of posts here but most were regarding 1/2 ton PUs, which seem to have a higher tow rating than their SUV counterparts. I did find one post from PSMike, Towing with Ford Expedition - think I am OK?, that was quite eye opening ( http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/24894612/srt/pa/pging/1/page/1 ). I've been around cars and trucks and have busted up a number of them, usually out in the middle of the desert, so I understand the consequences of breaking vehicles. I have no interest in sheering off axle bolts, etc, or having the TT guide me into a bridge abutment because I pulled a bit too much. So, here's the drop on the TV and TT for context:
TV:
2007/2007 Ford Expedition 4x4, 5.4L sparkplug eating V8
Max Towing - 8600 lbs with Heavy Duty Tow Package
Max WDTW - 900 +/-
TT:
Jayco White Hawk 23MBH
Unloaded Vehicle Weight (lbs)
4,610
Dry Hitch Weight (lbs)
645
Gross Vehicle Weight Rating (lbs)
6,500
Cargo Carrying Capacity (lbs)
1,890
Jayco White Hawk 30DSQB
6,045
765
8,250
2,205
I know the first TT is a bit small but so is my budget. I'd prefer to go with the second TT but it is not 1/2 ton tow-able.
Based on the numbers of the Ford Exp and the 23 MBH I believe this combination could work. Because I have four almost grown boys, a wife, and a dog, there's not much room in the vehicle for cargo based on what I have read previously. I also think I'll be pushing 700 to 1000 lbs cargo in/on the trailer, including propane, batteries, etc. That puts the trailer at 5600 lbs + 7900ish for the truck et al = 13,500lbs which is darn close to the MAX 14,100 combined gross. Hitch Weight would be around 760 lbs (645 + 15% of cargo) . The weights are under but not by much. So, questions…
1) Does the combination of Ford Expedition and 23MBH work or do I need to ditch the 1/2 ton SUV dream and consider a 1/2 ton crew cab with a front bench or a 3/4 ton burb (assuming I can get one of those…they are, as other posters have noted, hard to come by)?
2) Moving to TT number 2, I will need a 3/4 ton to pull this, correct?
I appreciate the extra eyeballs of experienced RVes, especially as I have so many numbers and combinations floating around in my head. Thanks for any and all input.
  • RoyB's avatar
    RoyB
    Explorer II
    We see alot of folks with more kids then sleeping quarters go with the idea to setup a close-by tent to sleep in. The boys especially seem to like this idea...
    I am setup here with more batteries and INVERTER and can run a 120VAC drop cord from the trailer to the tent in a heart beat for small appliances to used inside the tent when camping off the power grid.
    My crazy kids and friends would rather get into a sleeping bag on top of the camp site picnic table then sleep inside anyway haha...
    My setup has plenty of room just for us with one extra tent bed and tow's great with my F150 truck. With the very low wind drag my F150 gets great gas mileage.. My OFF-ROAD POPUP has all the modern appliances just not alot of walk around space inside which makes us live outside the trailer alot which is not really a bad idea anyway...
    My 2010 F150 truck setup would live very nice with the 22-24 foot pull trailer setups. The truck bed and the 5x8 front deck on my off-road popup setup gives us plenty of room to bring along all of our "very necessary" things to bring along...
    This is how we like to camp best...
    Roy Ken
  • 6k dry, 7000-7500 pounds loaded TT plus a large family is beyond most half ton payload and receiver limits. That's close to 1000 pounds of loaded TW. As you shop, look for this sticker on every 2006+ vehicle. You'll have to subtract the weight of your family and the left can be loaded TW as long as it is under the receiver rating.
    Are you open to passenger vans? They are relatively inexpensive especially used. A GM 2500/3500 with 6.0L/3.42 axle will have more power, similar fuel economy to the Expy. And it will comfortably handle 8000 pound dry Travel trailers. If you are already open to 3/4+ ton TV, then you have far more options of TTs. The $20-25k 30-36' BH TT market is crowed with carious types, features, conveniences, and luxuries. I.e., the Whitehawk is not high on my list for the $.
    Otherwise, we love our 3/4 ton Suburban. 2008+ are mechanically the same. They are rare as the economy was down in 2007-2010 and production dropped. But they all come with the required equipment for towing vs. the half tons which often have poor gearing and trans cooling which can also be a pain to find the right ones.
  • Looks like a good combo (1st one), I think you are right to stay around a max of 6500 TT GVWR for the truck/trailer combo. That said, it appears that you might be able to get into the 25BHS model with that TV as well. A little longer, but approx. the same weight. It looks like a hybrid of the two you are looking at. I assume you have kids (as I do) and I love having the privacy of a bedroom in the front. Good Luck with your decision.
  • Expy + 23 TT looks like a good combo to me. The 34' may be 'technically' within allowable limits but realistically it's too much trailer. That long a trailer, so close to weight limit, with shorter wheelbase tug (compared to a pickup truck) is a combo that could make the drive very tense and exciting (in a bad way).
