Desert_Captain
Feb 07, 2013Explorer III
linchat wrote:
Expedition EL: 920 Hitch, GCWR 15000, GVWR 7540 (1400# Cargo) GVW:6140
Now looking at the Radiance Radiance 28QBSS
GVWR 7640 Dry 5410
Hitch Dry: 585
Length 32'
After reviewing this TT, even if I max it out, it still keeps me in limits for the TV I think. Though I seriously doubt I will be adding 2k of weight since I will most likely not be doing dry camping.
Seems like a better fit?
Anyone any experience with this brand?
Sounds doable but you will be pushing the GVWR of your Expy. If you only load the TT to 6500# that will generate Tongue Weight of 845# which comes right off your 1400# of payload leaving 555#. Subtract another 100 for the WDH and now you're left with 445 and that is all (bodies and gear), that you can put in the TV. Load both the TT and TV lightly and you should be OK. A 32' TT is still a lot for a 131" wheelbase TV. Good Luck! :C
