- Aluminum_SidingExplorerI'd go with a lighter trailer
- mister_dExplorer
SprinklerMan wrote:
I pull a 30 ft sunset creek with a v10 excursion . Its a 3/4 ton truck basically . My truck is rated for 10k towing , camper weighs 8400lbs loaded .I know its back there. What always concerns me when towing is braking , I can stop with the 3/4 tons brakes , I wouldnt trust a 1/2 ton vehicle with towing weight with family on board .
Your tow vehicle should not be using it's brakes to be stopping the TT.
OP - there are many lighter trailers out there - I would do my best to stay away from the limits. We towed our current TT with an Expedition at every limit and it wasn't pretty. I would also try to keep it 30' or under. - linchatExplorerWhat expedition do you have? The EL?
- CarolinaHokieExplorerWe have a ford expedition and we tow this lightweight model. We had some problems with it initially (bought it new), but just want to show you that there are lighter bunkhouses out there. I would not tow anything bigger than this with my expedition! (this is 5085 lbs dry and 7530 gvwr)
http://cruiserrv.com/shadow-cruiser/s_280qbs/specifications.html - bedellExplorerSpeaking to the question of interior height: I am 6'6" and we have an Open Range TT which has lots of headroom for me; even good clearance under the speakers and lights. I think it has as much headroom as the main level of a fifth wheel. On the other hand, the trailer is 32ft long and weighs just under 7000# empty weight. We tow with a long bed Silverado 2500HD so it is a pretty comfortable tow.
Happy trails. - Mickeyfan0805ExplorerMake sure you consider the long-term implications if you plan to keep these for a while. You may have 4 'small' children now, but they won't stay that way. As your children grow, the weight on your TV will grow with them. People will argue over length, adjusted ratios, and all sorts of things. IMHO, however, there is no getting around that a family of 6 will far exceed the GVWR of a 1/2 ton vehicle long before they exceed anything else!
FYI - We are a family of 5 with 3 small children, and I figured we had to be under 5k 'dry' in order to fit within the GVWR's of an Expedition. - TerryallanExplorer II
SprinklerMan wrote:
Terryallan wrote:
SprinklerMan wrote:
Terryallan wrote:
Again. Neither the brakes on your Excursion, OR a 1500 truck , are rated to stop the trailer. The brakes on the Ex are only rated to stop the GVW of the Ex. Not the TT. That's what the TT brakes do.
Don't be fooled in to thinkin a bigger truck is rated to stop a bigger tailer. It's not. Anything over the GVWR of the TV, the TT brakes have to stop.
He Did , his trailer connector came loose , no brakes on a 15,000 lb tripple axel fifth wheel . he had to replace his brakes and dry off his seat.
They may not be rated to but they will , The brakes and calipers are bigger on my excursion vs my old f 150 , yes the ex has a greater curb weight . but it will stop both rather well with out the trailer brakes. Accidents happen , as well as mistakes , a friend had his trailer plug come loose on his tripple axle 5th wheel pulling with a f 350 dually , going down an good incline , he stopped safely , found a parts store spent the next 2 hours replacing all the brakes and front rotars. Bigger brakes , better stopping .
Overloaded barkes are overloaded brakes no matter what they are on. As for the down grade. I use very little brakes on a down grade. I let the engine hold it back, Touching them only briefly for turns. Sounds like he rode his all the way down.
Lessions, and a exhaust brake could be his friend - APTExplorerThe dry tongue weight at 925 pounds is more than your receiver is rated. Loaded, it will only go up. For a large family, I estimate the TT will be at 8500 pounds with about 1000 pounds of tongue weight. That is far too much for your Expedition.
You need to look at two different limits for estimating how much RV you can tow, not tow rating. Open the driver's door and look for this sticker on the door or door jam.
Subtract your estimated weight of family and stuff you think will be inside the Expy.
Then look at your receiver for something like this sticker:
Take the lower of the two and multiply by 7.7 for an estimated loaded TT weight.
My guess is you need to stick to TTs under 6k dry with under 650 pounds of dry TW. - BigBoy11Explorerlinchat, you are running it REAL close! I have a 2011 Expedition XLT and a 31 ft. Kodiak that is 5900# dry weight and once we get loaded, full of gas, supplies, all the "stuff" we carry in the TT, there are times I wish I had more uuumph! The brakes are no problem but the pulling power up some of the mountains are a bit of a struggle.
- SprinklerManExplorer
44,050 PostsLatest Activity: Mar 24, 2021
